Nimelt on kuulda olnud juba mõni aeg tagasi uudiseid ühest HPI spetsiaalsest driftimiseks disainitud mudelist.
New from HPI:
Aiming toward the strongest drift my star.
You completed "PRO-D" with the hand of the JAPAN R&D team which masters the drift in the domestic drift category which is maturing. It makes most main parts the new design, the numerous prejudice which surpasses also the competition touring car actualizing the drift feeling of the highest quality. The preponderant flying distance "of PRO-D", preeminent control characteristic designates everyone as the ?.
The yaw axis to move by the fact that the motor which is rotary ones is arranged in the front midship, easier drift is possible.
Easy ejection battery holder
Adopting the Easy ejection battery holder. The straight pack is possible of course, loading the rose cell and the Li-Po battery
Direct vent system gear box
Approximately you adopt the airtightness gear box, not only the circuit considering travelling and maintenance characteristic with the street
Chassis roll selection system
With the adoption of the chassis roll selection system, position of the selector it is changed by the fact that roll rigidity of 2 sorts selective possibility.
Orange alumite aluminum part
Adopting the aluminum part of the orange alumite being completed which gives fresh and powerful impact for the section
1/10 scale shaft drive 4WD drift car "PRO-D" leading particulars
* Total length : 355mm
* Full-width : 190mm (at the time of 0mm offset wheel installing)
* Wheel base : 255 - 257mm
* Wheel base : Completeness approximately 1500g
PART#10525 - Pro-D
Jääme siis huviga ootama, millal meie Maal seda näha ja käega katsuda saab
Mida Drifti huvilistele HPI Pro-D
