Multiplex servod
Moderaator: Sinuhobi
Sinuhobi
Sinuhobi
Multiplex servod
Postitus Postitas Sinuhobi » 27.03.2007 21:04
Oleme siis isegi 1:6 masinate peal katsetus faasi läbi elanud ning tulemuseks siis see, et Hitec HS-5745MG servo on küll hea aga parim Multiplex Servo Rhino Digi 4 on best of the best.
Tehnilised andmed järgmised:
This is the Rhino Digi 4 Digital Metal Gear Servo from Multiplex.
FEATURES: Created for 1/5 and 1/4 scale car market
Metal gears
Motor heatsink
Large diameter super strong output shaft
Triple ball bearing
INCLUDES: One Rhino Digi 4 metal geared digital servo
One servo accessory package containing one large four arm servo horn, one single arm servo horn,and servo mounting hardware.
Instruction sheet
REQUIRES: Application requiring large servo
SPECS: Length: 2.32" (59mm)
Width: 1.14" (29mm)
Height: 2.17" (55mm)
Weight: 5.14oz (165g)
Speed: .12 sec/40°@ 4.8V and .10 sec/40° @ 6V
Torque: 180 oz-in @ 4.8V and 205 oz-in @ 6.0V
HIND : 1537.00 EEK
Hakkame just uut tellimus kokku panema ja seega aega kuni Neljapäevani (29.03.2007)
Viimati muutis Sinuhobi, 28.07.2007 21:22, muudetud 2 korda kokku.
Sinuhobi
Sinuhobi
Postitus Postitas Sinuhobi » 29.03.2007 23:54
Hetkel teema lukku ............ servode partii kvaliteedikontrollis !
Sinuhobi
Sinuhobi
Postitus Postitas Sinuhobi » 02.05.2007 15:09
Kaup piiratud koguses laos !
Sinuhobi
Sinuhobi
Postitus Postitas Sinuhobi » 01.07.2009 10:21
Suure skaala populaarseim servo taas olemas
3 realiseeritud ning 3 veel järgi
Kes ees see mees !
Norm Hind : 1799.00
Soodushind : 1599.00
Saadaval Hobimaailma kaupluses
