Autod ei sisalda servosid ega ka muud elektroonikat !
Pikem jutt :
Technical description of the FG Competition Chassis, width 400 mm:
The undercarriage of the Competition is built on a non-twisting 8mm alloy chassis with sparings on top for a low centre of gravity. All screw heads are countersunk at the bottom side. Wishbones as well as most of the chassis parts are manufactured in high-quality alloy.
For a better distribution of the wheel pressure we inserted the well-experienced 2-damper front axle with ball stabilizer. The rear axle is equipped with the adjustable alloy differential, a stabilizer and the well-tried FG ball drive.
King pin angle, toe-out and toe-in can be adjusted without any difficulties at the front and rear axle by means of right-/left-handed threads. All driving parts are hardened, all rotating parts are supported by ball bearings. The chassis can either be ordered with Tuning brakes or with hydraulic brakes. The Competition is equipped with BBS or ATS wheels and competition tires. The Zenoah G230RC engine with FG inlet silencer and FG Power Tuning pipe guarantees enough power. The Competition is delivered as a kit.
Equipment of the FG Competition: CNC-cut 8mm alloy chassis, adjustable locking differential with plug system, FG ball drive, upper and lower alloy wishbones at front and rear axle, ball stabilizer for front axle, 4 oil-pressure shock absorbers with volume control, front alloy axle mounts, front and rear alloy uprights, alloy upright lengthening, hydraulic or Tuning disk brakes at front and rear axle, alloy servo saver B, alloy rear axle base, alloy gear plate, alloy gearwheel 23 teeth, alloy gear carrier, 10mm alloy balls, foam front bumper, carbon fiber side guards, Zenoah G230RC engine, FG Power Tuning pipe, FG inlet silencer, receiver box, ATS or BBS wheels with competition tires, without body set, decals and radio control system.
Kered Läbipaistvad ja sisaldavad tulede kleebiseid !
Nr. 7239 Mercedes C-Klasse DTM 2004
Nr. 7249 Mercedes CLK-DTM
Nr. 7254 Honda Accord
Nr. 8044 BMW 320
Nr. 8049 BMW GTR
Nr. 8165 BMW M3 GTR
Nr. 8075 Alfa Romeo 156 WTCC,
Nr. 8144 BMW 320si WTCC,
Nr. 4149 Audi A4 DTM,
Nr. 7229 Mercedes C-CI DTM 06 ,
