Length 22.91 inches (582mm)
Front Track 16.38 inches (416mm)
Rear Track 16.48 inches (418.5mm)
Center Ground Clearance 3.86 inches (98mm)
Weight 151oz (4.29kg)
Height (overall) 8.275 inches (210mm)
Wheelbase 14.1 inches (358mm)
Front Shock Length 87mm
Rear Shock Length 87mm
Front Tires (pre-glued) Talon (5.75" x 3.8")
Rear Tires (pre-glued) Talon (5.75" x 3.8")
Front Wheels 3.8" Gemini (black-chrome)
Rear Wheels 3.8" Gemini (black-chrome)
Speed Control Type EVX-2 Forward/Reverse/Brake
Motor (electric) Dual Titan® 550,
Fan Cooled (21-turn)
Transmission Single-Speed (2nd gear only)
Overall Drive Ratio 18.67 (stock, out-of-box)
Differential Type Sealed Hardened Steel Bevel
Gear Pitch 32-Pitch
Chassis Structure/Material Molded Composite Nylon Tub
Brake Type Electronic
Drive System Shaft-Driven 4WD
Steering Bellcrank
Radio System Traxxas TQ
Top Speed 30+mph
Skill Level 2
Required Batteries & Charger 8 "AA" (transmitter)
Two NiCad or NiMH (stick)
7.2V or 8.4V Charger (6 or 7 cell)
PIKEMA JUTU AUTOST LEIAD SIIT
Kellel huvi siis läbi Saksas asuva lao suudan antud masinat pakkuda RTR versioonis HINNAGA 7800.- EEK-i
Esmapilgul näeb asi väge ärev välja .......... nüüd siis akud peale ja sõitma
