Esialgselt saabub siis versioonis Ready for Radio RR 26 3001
Specification:
Fuselage length: 855 mm
Rotor diameter: approx. 770 mm
All-up weight: approx. 1250 g
VAATA VIDEOT
Fascinating Simple Robust
The FUNCOPTER is the perfect first or second step into the world of model helicopters. Above all it is the logical next move for any
model flyer who has gathered some initial experience in flying co-axial helicopters, and is now looking for a new challenge. Its a
great choice - and will not strain the modelling budget!
FUNCOPTER has to be your first choice in terms of both price and quality. Its impressive features are its resistance to crash damage,
its patented folding rotor blades, and the blades mounting. All these advantages help to keep your outlay for replacement parts
within easily affordable limits.
The design of the machine is based on the proven, patented ideas incorporated in the LMH (Lite Machines Helicopters - familiar
machines the world over), combined with our own ideas to create an unusual helicopter which provides almost unlimited flying fun
- especially if you are a relatively inexperienced pilot.
The FUNCOPTER is supplied completely assembled and adjusted.
The helicopter offers many fascinating features, not least its extremely quiet direct drive system (no gears) which produces a very
unusual sound. The mechanical system is assembled from just a small number of parts, and is of straightforward construction. This
makes the FUNCOPTER extremely easy to maintain and repair. The front fuselage is a slide-in component which can be disengaged
with a push-button and pulled off as a unit; this provides unrestricted access to the interior and the battery compartment, making it
fast and easy to replace the flight pack.
The FUNCOPTER really is designed for sheer fun, and its ingenious overall design and many neat technical details make it unique:
you just cant fail to have fun with it. Its simple to control, and you can expect to fly it successfully within a very short time.
A simple four-channel radio control system is all thats needed to control the model; no mixers or other complex settings are required
at the transmitter.
The plus points:
With its consistent overall design the machine is ideal for beginners
to helicopters, modellers moving on from co-ax machines,
and helicopter pilots wanting a minimal-risk practice chopper.
Fixed pitch helicopter no adjustments required: full control using yaw,
pitch-axis, roll and throttle functions
Different blade holders for matching to different payloads (battery size)
Easy to repair (simple construction, few parts, few screws)
Retail packaging converts into convenient transport case
Full-body fuselage with modern, attractive looks, easy to see in the air
Fuselage made of ultra-robust EPP particle foam; heavy-duty plastic parts
(Whisper-quiet) direct-drive power system
Long flight times - up to fifteen minutes with 3000 mAh battery
Robust, virtually indestructible construction:
flexible rotor blades which fold upwards,
special sprung landing gear and ungeared power system.
Set contents:
All versions (AK and RR)
of the FUNCOPTER are factory-assembled,
with the brushless motor installed.
The following additional items are required for the AK version:
3 x Tiny-S servos # 6 5121
1 x MULTIcont BL-37 II speed controller # 7 2276
1 x MULTIgyro 300P gyro. # 7 5503
In the RR version all these components are included, installed and connected.
Recommended flight battery
Li-Batt eco 3/1-2000 # 15 7231
or
Li-Batt eco 3/1-3000 # 15 7236
Hind siis saab olema 5,635.00EEK
Kuna see paistab tõsiselt lollikindel olevat siis ootan antud asjadust ise suurima huviga
