Müüa selline vähekasutatud komplekt siis
http://www.rcmart.com/catalog/rc-motor- ... th=293_949
Quark 22A brushless Controller
22A Pro Car Controller
Specifications:
# 22amp continuous/ 35amp surge@ 10seconds
# 9NEW Drag Brake peofiles
# 3NEW Reverse Options
# Super-Low 0.0065Ω Resistance
# No Cogging!
AON 4900KV brushless mootor
Motor For Mini-Inferno, RC18, 18T, 18MT
Specifications:
# KV: 4,900
# Max Current: 28A
# No Load Io: 1.2A Resistance: 42.3mΩ
# Avg Current: 8A-22A
# Dia: 24mm (Speed 370)
# Length: 33mm
# Weight: 65g
# Shaft Dia: 2.0mm Max Watt: 200
# Motor Constant: N.A.
# Magnet: Neodymium
# Direcr Drive: For ducted fan only Gear Box: Cobri, GWS, EFlight (4.5 & up) with 7" to 12" (SF or E type) prop.
# Mini cars/trucks: 1/8 to 1/16 (ideal for RC18T, RC18MT & Mini-Inferno)
Features:
# Low cogging
# No electrical noise
# Precision Machining
# Hop-Up parts available
# Parts avail for repair
# Anodized case
# Dual ball bearings Removable end-bells Plug and Play Efficient slot-less design
# Zero maintenance
# Hardened steel shaft
# Reliable at high RPM
# Single poece magnet
# High current connector
Asjaga on KIIRE !
M: Brushless mootor+ESC. KIIRE ! ! ! Müüdud.
Viimati muutis syncmahv, 12.11.2008 18:42, muudetud 1 kord kokku.
