Servo BMS-410 STD
nppc
Servo BMS-410 STD
Postitus Postitas nppc » 01.02.2006 08:53
Täitsa uus. Hind 200.-
Täpselt see mis on siin:
http://www.amdhobby.com/product_info.ph ... f6d8cc61b9
Specifications:
# Weight: 42g / 1.46oz
# Size(mm): 40.5 x 20 x 38.5 mm
# Size(inch): 1.60 x 0.78 x 1.54 inch
# Speed At 6.0V: 0.22sec / 60 deg at no load
# Torque At 6.0V: 4.4kg/cm , 60 oz/in
# Ball bearing: none
# Metal Gears: No,All of nylon gears
# Operating Voltage Range: 4.8V to 6.0V
# Connector Wire Length 300mm(11.81in)
# Connector Horsing Universal connector
