NIMH aku 2800mah 9,6 v hind: 12eur
Brand new 2800mAh 9.6V NiMH rechargeable battery
* 2800mAh 9.6V rechargeable Battery
* No memory effect, recharge up to 1000 cycles
* 100% quality Japanese battery cells
* 100% Q.C. of every battery
* Manufactured by Hi-Capacity power products.
* Mini-Tamiya connector
Standard suurusega servo Hextronic 6.9kg / 39.2g / .16sec Twin bearing.
hind: 5eur
Dimentions: 40x20x38mm
Weight: 39g
Speed: .16sec/60Deg
Stall Torque: 6.5kg
Dead Bandwidth: 4us
Voltage: 4.8~6v
Brusshless mootor koos adapterite spinneri ja muude jubinatega.
hind 15 eur
# Motor
# Rotational Speed :850 (kv) RPM/V
# Continuous Current :20A
# Max. Current :28A
# Input Voltage :6 - 11.1V
# Max. Efficiency :98%
# No Load Current :0.6A
# Internal Resistance : 272m(Omega)
# Motor Weight (Motor only) : 60g
# Motor Dimensions (Diameter x Length) : 28* 30mm
# Propeller Dimensions : 11" x 5.5"/ 10" x 4"/ 9" x 6"
# Input Battery Types : NiCd/ Nimh/ Li-po Battery
# Recommend Model : Airplane
[/i]Tartu
