Müüa paar uut mootorit:
EMax CF2812 Brushless Outrunner 1534kv
Spec.
Weight: 39g (with wire & sticker etc)
Shaft: 3mm
Motor Length: 46mm
Diameter: 28mm
Stator Size: 22x10mm
Suggested prop: 7x4 or 7x6inch
Voltage: 11.1v or 14.8v (3-4S)
Kv: 1534RPM/V
Data ;
Prop size: 7x4
RPM: 12250
Max Curr: 10.5A
Thrust: 580g (1.27lb)
Prop size: 7x6
RPM: 11000
Max Curr: 15.5A
Thrust: 730g (1.61lb)
Hind: 9.-/ tk, või 16.- / 2tk
