5-elemendiga parda aku ja digiservod
Kes kasutab? Nimelt rusika-reeglina keelatud ju (või mitte-lubatud) 5-elemendiga NiCd/NiMH kasutamist juhul, kui kasutad digiservosid. Kas on olnud probleeme? Äkki mõne mehe pidevad servode läbi kärssamised ongi selle tõttu ?
Probleemiks see, et täis laetud 5-elemendi puhul on kogupinge kõvasti üle 6V ja digiservo mõeldud töötama 4.8 - 6.0V (4x1.5V patareid).
Miks küsin? Sest omal plaanis mitmele olevuele digiservod peale panna ja mõtlengi siin, mida teha... tegelikult peaks parda 4-elemendi vastu vahetama ja polekski probleemi.
üks vana ja kulunud jutt Hitec / Multiplex arendus osakonnast !
how to avoid the damage of
digital servos.
First you have to understand, that digital servos are designed for fast
powerful controlling of models at a best weight and for a price within a
hobbiest's budget. This means: You can't get a high speed, lightweight
fast power servo with superb price that will withstand all kind of
overload conditions without damage.
If your car crashes and any kind of servo blocking happen a digital
servo will try it best to move and even a small offset will cause the
servo to fetch full current to start moving as fast as possible. This
current is near to short circuit condition because the motor is not
running. With an unblocked servo, this is only for a short moment
causing only little thermal load.
The servos will withstand for a while this overload condition, but
running the servos at the upper voltage limit ( keep in mind that 6 Volt
means 6 Volts and NOT 5 cells fully charged .. will not blow up the
servos at once but will add extra load) gives you not only more power
but also less tolerance for blocking condition. Further more, the
overall temp of the servo will be higher before the block condition
happens and you loose extra headroom.
So the first step to avoid blown up servos is to use 4.8 V supply
voltage. Second is to use mechanical devices that avoids blocking of the
servo even if the steering is blocked.
If you think you need the max. power and speed out of the servo please
understand that there is no headroom left for overload situations.
Of course it might be possible to design a servo with 100 % overload
protection, but this will costs a lot of more money ( a estimate was
about 15 times of todays price ..) and if we see the small overall
failure rate there is no need for 95 % of the user for extra protection.
( and be sure.. anyone will suggest to bridge the overload fuse in order
to get out more speed, power etc.. )
best regards
Olaf Wessels
Service Department Germany
digital servos.
best regards
Olaf Wessels
No täpselt... seda ja neid jutte tean väga hästi! Ei soovitata ja põhjendus ka väga loogiline, samas jätab otsa lahti... kes tahab riskida, võib proovida
Ootaks isiklikke kogemusi! Kes "ellu jäänud" ja kes "surma saanud" 5-elemendiga digiservode kasutamisel.
njahhh räägin siis omadest kogemustest
Kokku läbi kõrvetatud 3 digikat.
Põhjuseks reeglina kinnikiilunud roolisüsteem mis tekitab servosisest pinget nagu ka spetsialist väidab
Kasutusel olnud akupakid mis kõik 5 elemendiga 6V ja kas 1500 - 2000
Futaba 9451 pole veel siiani ära surnud. 5 elemendiga NIMH aku kenasti toitnud.. krt seda teab. Ja nüüd on isegi on-road masinal peal, mis saab juu vooli 7,4V akust?
Zebra1188: ESC'il on tõenäoliselt siiski BEC vahel...
a mina olen ka siiani digiservot 5cell nimh akuga kasutanud ja siiani toimib.
eluaeg 5-cell aku ja digiservodega sõitnud. surevad kõik lõpuks millegisse, igavesi asju ei ole, aga ülepinge tõttu pole veel ükski läinud. Viimane tase on hüpata mootor trükkplaadi küljest lahti
Huvitav, et enamik kärutavad oma digiservosid 5-akuga. Kui töökindlust tahad ja finaal-sõidus mitte riskida servo kärssamisega, tasuks 4-elemendise parda-aku poole vaadata
Miks? Kui arvad, et su digiservo pole 4-akuga piisavalt võimas, hangi võimsam digiservo. 5-aku kasutamisel muud eelist pole, kui servo väljundvõimsuse tõstmine. Veel parem oleks muidugi 2S LiPo ja UBEC (impulss-muundi) kasutamine, mis pidevalt näiteks 5.8V välja annab.
FYI: Minu esialgne küsimus oli üle-üldse lennuki servode ja aku peale mõeldes küsitud Laksan igaksjuhuks siiski alguses 4-elemendise kõigepealt ja kui tundub, et jääb kiirust ja võimsust puudu, siis panen 5-elemendise. Lennuki puhul pole servo täis-koormuse all sisuliselt kunagi ja päris mitmed kasutavad muretult digiservosid 5-akuga.
See ülepinge jutt on täielik BS kuubis. Ma ei tea kedagi, kes teaks kedagi, kes kasutaks onroadis 4 akuga toidet. Absoluutselt kõik autod on tehtud 5-purgiste akude jaoks (OK, v.a. RTRid, millel on 4xAA tray kaasas, aga me räägime ju digiservodest ehk võistlusautodest) ja nii nendega ka sõidetakse.
Minu kolmandal suveetapil surnud gaasiservo oli sama vana kui mu 3PK pult, ja see on juba väga vana... ma pakuks lambist ~5 aastat. Üks esimesi 3PKsid igatahes.
Oh yeah, ja 4xAA pinge on ka uuena üle 6 voltsi...
Võib ju praktikas BS olla (seda vastust ma ootasingi, tänud ollo ), aga vähemalt tootjad kaverivad oma ässi selle jutuga...
Ja miks uued võimsad digiservod on metallkorpuse ja radiaatori-kujuga ? Sest suured võimsused ja ülekuumenemine on probleemiks. 4-akult 5-le üleminek aga halvendab olukorda veelgi. Eks peamine "sissepõlemise" oht ongi siis, kui servo saab täiskoormust väga pikka aega. Kuumenevad nii transid kui mootor. Voolutarve võimsal servol ~2A ja 6v >> servo tarbib maksimaalselt üle 10W !
Aga mina sain oma küsimusele piisavalt ammendava vastuse ja panen järgmiseks korraks ka 5-akuga parda-toite.
Lauri - on tootjaid ja tootjaid. Ja need tootijad kes kirjutavad oma servo spetsi, et see kannatab 5-se pakiga kasutamist ei kavereeri midagi. Kui sa võtad servo mille spets ütleb, et see on ainult 4-se pakiga kasutamiseks ja kasutad seda 5-sega, siis oled rumal. Aga sa ei pea sellist servot võtma.
Arne
Arne
