Mida arvata sellisest saatjast :
Mudel : CRX 40MHz
The modern computer-controlled 3K - FM plant in the pistol Design for the hard competition employment.20 model memory, highly soluble graphics display, digital trim, a push button switch for transmission change-over and a user surface with all adjustment possibilities, which can be served simply, which the successful driver wishes itself.
Ergonomic form for optimal operation and comfortable handling also when long running.
Highly soluble multi-pixel display
During the enterprise adjustable way limitation with the steering element (dual rate)
Braking distance adjuster
ATL (adjustable travel length) - switches for the braking distance
Spring action attitude for steering wheel
Acoustic trim neutral identification
Slide switch for 3. Channel
3. Channel digitally trimable
Changeable grasp border, as option in different colors and two sizes.
Comfortable, foam rubber-referred steering wheel.
Load socket to the enterprise also loadable batteries.
HF-announcement over LED
Digital trims
Menu scrolling in two speeds.
Acoustic Akkualarm
Running-time meter programmable parameters
Model name (6-digit)
Model memory (20)
Sub Trims
Effect channel 3, (switch, slidegate valve)
EPA - Terminator point attitude
Expo for steering element and gas/brake
ABS
Mixer steering element> AUX/Gas> AUX
Timer (up/down)
Servo Reverse
Copying function
RESET on factory settings
Set contents
Transmitter AGRESOR CRX
Receiver DCX;
Pair of quartz
1 servo HS-325HB
Switch cable,
Senderakku
Loader CG 22A
Technical data:
Aggressor CRX transmitter:
Modulation: FM
Channels: 3
Channel raster: 10 kHz
Operating voltage: 9.6 V
Weight: m.Akku
Link infoga
siit
Maksab siis seal 179,9 EUR + muud kulud juurde !
Või on miskit paremat välja pakkuda ?!
Hitec saatja
Hitec saatja
Täpselt sama raha eest aga ilma lisanduva postikuluta ja tasuta koju kätte veidi parem pill: Graupner/JR XS-6 http://foorum.hpi.ee/viewtopic.php?t=1352
