Mystery ESC 80A Brushless Motor Speed Controller
Feature :
* Effectively the flight performance
* Low resistence
* High rate PWM
* User programmable brake
* Low voltage auto setting based on battery
* Throttle range self-adjusting
* Soft start ramp up
* Runs motor in forward or reverse
* Auto motor cutoff with reset
* Safe power arming program ensures motor will not run accidentally after turn on
* Low torque start
* Auto shut down when signal is lost
Specification :
Size: 76.6mm x 28.3mm x 914mm
Weight: 52g each
Constant Current: 80A
Max Current: 90A
Input Volt: 6V - 20V LiPo and NIMH
Low-Voltage Cutoff: Auto detect and set
Mounting screw
Main Functions
1. Safety mode: the motor won't start no matter what the position of the control stick is when
switched on the RC unit.
2. Brake Setting: On/Off (factory setting is off)
3. Three point battery type and low voltage selection.
4. Software reversion of motor turning direction.
5. Low current protection: ignore/reduce power/shut off
6. Temperature protection: reduce power when the temperature reaches 120 degrees C
7. PWM frequency: 8KHZ/16KHZ
8. RPM setting: 20,000rpm/50,000rpm/100,000rpm (60A/80A Only
HIND 400
TEl 5566 3168
M. Brushless ESC 80A
