Tamiya TEU-101BK ESC
Forwards, brake & reverse 23 turn limit electronic speed controller 25EUR
1300mAh LiPo Akku 3s 11,1V 15C koos laadijaga LiPo-Balancer 2s/3s 25EUR
Buggy rehvid 17mm 6 Kant kroomveljed ,40mmx120mm 20EUR
Pilte näeb asjadest http://www.okidoki.ee/item/558947/" onclick="window.open(this.href);return false;
telef 5106219
M:, ESC tamiya TEU-101BK jm
Re: M:Nitro auto Ansmann Reaper Buggy 1:10 2200EEK
Compatible with Tamiya 540 and Sport Tuned stock motors
Reverse function can be changed to brake for races where reverse is not allowed
Compatible with Futaba, Tower Hobbies, Tamiya, KO, JR and Airtronics
Z connectors
Set button allows adjustment of maximum forward and reverse throttle trigger settings
INCLUDES:
One Tamiya Forward and Reverse Electronic Speed Control with motor
connectors, Kyosho style battery connectors, receiver connector
and receiver switch pre-installed, instruction sheet
REQUIRES: Installing in vehicle and connecting motor and battery
SPECS: Length: 1.6" (40.7mm)
Width: 1.4" (36.8mm)
Height: 0.88" (22.5mm)
Weight: 1.9oz (54g)
Control System: High frequency drive
Max Continuous Current (FET Spec): Forward 60A, Reverse 60A
Power Supply: 7.2V (with 6 cells
Output Voltage for Receiver: 7.2V
Output Current for Receiver: 1A
Z connectors
INCLUDES:
Weight: 1.9oz (54g)
Re: M:, ESC tamiya TEU-101BK jm
Tere,
Kas ESC on veel müügis? Kus asub? Milline on hinnasoov?
Tervitades,
Ilmar
t. 5047879
Tervitades,
Ilmar
t. 5047879
