Saadaval** mõned RR5 Competition Spec '14 mudelid* (tellimisel, ettemaksuga 50% ulatuses, hind 900€ ).
Competition mudeli Omadused/varustus
CCD drive shaft and axle - STD
8620 differential spiral bevel gears - STD
Composite planetary differential case with 8620 steel gears - STD
Easily removable one-piece electronics tray - STD
CNC machined 5083 alloy chassis - STD
Extended wish-bones - (I3 rubber enforced (flexible for durability))
Micro Stud tires - STD (White compound)
24 mm hexagonal rim-blocks - STD
Composite molded durable side guards - STD
Easily removable composite front, rear and center diff houses - STD
Ultra durable front and rear adjustable steel disc brake rotors and pads - Single Disc (Steel Pads)
CNC Machined 7075 air craft alloy front and rear towers - 5mm
Optimized multiple suspension holes - 2 shock absorber, 2 roll-center linkage
Coil-over extended composite shock absorbers - STD
Composite shock cap and ring - STD
Ultra hardened steel transmission gears - STD
No-Stress effect poly-amide front and rear bumper - STD
Ball output couplings - STD (11SMn Pb37)
Super-Cooling RR5 air ventilation system
Rear brake only servo slot - STD
Viper Racing Air Filters - STD
Pre-cut RR5 Decal Set - STD
Fully composite body accessories - STD
Drive shaft boot - STD
Clear body shell - STD
Täiskomplektiks on veel vaja mootorit (ca 250€), väljalaset (ca 220-250€), pardaelektroonika (ca 300€) ja juhtseadet.
* - lisainfo tootja lehel
** - saadaval kuni septembri lõpuni
MCD RR5 Competition Spec '14
Moderaator: harg
Hüppa
- Üldine
- ↳ Võistlused
- ↳ EAMK võistlused
- Autod
- ↳ Off-Road
- ↳ On-Road
- ↳ Autode täiendused ja muud tarkused
- ↳ Uudised
- ↳ Tartu Klubi
- ↳ Väike-Maarja Klubi
- ↳ Keila Klubi
- ↳ saue HOBIzone
- ↳ LaitseRallyPargi mudelirada
- ↳ Mudelihall
- ↳ Põlgaste Mudeliklubi
- Lennukid/Kopterid
- ↳ Üldine arutelu
- ↳ Lennumasinate täiendused ja muud tarkused
- Stendimudelid
- ↳ Üldine arutelu stendimudelite teemal
- Veesõidukid
- ↳ Üldine arutelu
- Muu
- ↳ Üldine
- ↳ Foorumist
- ↳ Memuaarid
- ↳ Kasutajate pildigaleriid
- ↳ Arhiiv
- Kuulutused
- ↳ Ostan
- ↳ Müün
- ↳ Vahetan
- ↳ Oksjonid
- ↳ Tehingute tagasiside
- Kaubitsejad
- ↳ Sinuhobi
- ↳ RC-EST
- ↳ Mudelsport
- ↳ Hobimaailm
- ↳ Fast Hobbies
- ↳ MCD RC
- ↳ ClayPitRC.eu
- Võõramaa keeltes - In English - По Русски - Suomeksi
- ↳ In English
- ↳ Suomeksi
- ↳ По Русски
- ↳ WinterCup 2009|2010
- ↳ WinterCup 2010|2011
- ↳ HOBIzone WinterCup 2014|2015
