Kuna viimasel ajal on olnud palju jamasi NiMH akudega siis ausalt öeldes on minul kadunud julgus neid omast initsiatiivist lattu võtta. Samas tekitab see nagu kehva olukorra, kus võistlejad küsivad ja mul pole midagi anda.
Probleemi päritolu:
Lühidalt tõlgitud - akud on arendatud nii viimasele piirile, et nende ise-eneslik tühjenemine on oluliselt kiirem kui vanasti. Sellest lähtuvalt ks LRP ei hoia endal enam akusi laos vaid toodab neid vastavalt tellimusele ning tänu sellele pikenevad tellimuste täitmise ajad.LRP kirjutas:Yes, there are issues with batteries and 0V cells, but this is due to the improved perfromance of the cells. Everybody wants longer runtime and higher voltages and does not care about the pysical contruction of the cell itself. Up to a certain point internal resitance is so low that the self discharge rate goes up and away. And on this certain point we are at the moment.
For this reason we have decided that we will not stock any batteries any more. We are only producing them on order and so lead times went up. I can tell you that this situation will not change in the near future and everybody has to calculate with these long lead times.
Valikud:
Lühidalt on valikuteks siis kas:LRP kirjutas:If you want longlasting batteries where you will not have any issues with, you need to have the VTEC 4000 Longlife cells. These neither have the high self discharge rate nor the performance of a VTEC 4600. One price has to be paid. It sounds hard, but I can not say it in a more polite way.
a) VTEC 4000 Longlife, mille ise tühjenemine on oluliselt aeglasem
b) VTEC 4600 millel on jõudlust rohkem kuid, mida tuleb pidevalt laadida ka siis kui ei kasuta.
Detailsem valik on:
VTEC SC-4000UP Longlife single cells
77100 VTEC SC-4000UP Longlife packing unit 25 pcs. (erinevaid paking uniteid leidub - teie andke teada cell'ides selle valiku korral)
LRP HV˛ VTEC SC-4100UHV Stock Spec.
77211 LRP HV˛ VTEC SC-4100UHV Stock Spec - Race 6-cells
77212 LRP HV˛ VTEC SC-4100UHV Stock Spec - Team 6-cells
77213 LRP HV˛ VTEC SC-4100UHV Stock Spec - Factory Team 6-cells
77217 LRP HV˛ VTEC SC-4100UHV Stock Spec - Factory Team 5-cells
LRP HV˛ VTEC SC-4600 "Big Mama"
77311 LRP HV˛ VTEC SC-4600UP2 Big Mama - Race 6-cells
77312 LRP HV˛ VTEC SC-4600UP2 Big Mama - Team 6-cells
77313 LRP HV˛ VTEC SC-4600UP2 Big Mama - Factory Team 6-cells
77317 LRP HV˛ VTEC SC-4600UP2 Big Mama - Factory Team 5-cells
Kõigest ülal kirjutatust lähtuvalt pakun välja lahenduse - kogume soovid kokku ning tellime koos. Siis on tagatud see, et meie juurde ei jää üksgi aku seisma ning saate ise oma akud kohe värsketena kätte. Ilmselgelt sellise ürituse raames ka erihind. See on üks lahendus, mis võimaldaks asjal edasi areneda sest meie viimased kogemused huupi akude lattu võtmisega on näidanud, et selliselt ei kannata seda asja enam teha. Mul on hunnik 0V elemente, mida keegi ei taha ja ega ma ei julge anda kah (lihtsalt ei jõua seda negatiivset juttu hiljem kuulata).
Andke märku oma esialgsed soovid kujul
Toomas Kärner
15x VTEC SC-4000UP Longlife single cells
2x 77317 LRP HV˛ VTEC SC-4600UP2 Big Mama - Factory Team 5-cells
(sellele teemale vastates, ps'iga või emailiga)
Need esialgsed pole siduvad tellimused vaid indikatsioonid selleks, et ma suudaksin mingid lõplikud hinnad välja kalkuleerida. Siis tuleb lõplik tellimine, mis on juba siduv.
